- 19 Jul 2007
- notts , uk
There's a very good reason for that...
Regulation/ripple is rather rough on cooler master stuff.
link to this info ? , i use this psu and had no problems
The ripple was great but the voltage regulation was notThere's a very good reason for that...
Taken from this Cooler Master Silent Pro M1000 review http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story5&reid=166Summary
Rounding off to the nearest 0.5 as I usually do below the 9.5 total score level, the Silent Pro M at one thousand watts just barely misses a recommendation. Some aspects of this unit were among the best I have ever seen, but still others were among the blandest I've ever seen. That combination does nothing to help the score. Fortunately, if you are looking for a unit this powerful, this power supply is not a bad choice at all.
The Good:
fantastic ripple and noise suppression
held up full power at temperatures higher than rated spec
excellent low load efficiency
best quality FSP build I've seen in years
The Bad:
voltage regulation only so-so due to group regulated design
I did end up buying a new PSU in the end http://forums.overclockers.co.uk/showthread.php?t=18232524
Thanks JD...Stop posting silly nonsense and build the damn thing. Joking of course, extremely nice system you've bought sir (tips hat in appreciation). I hope the build goes well
I remember seeing them..I used a really great Thermaltake Toughpower VGA booster when I had SLI 8800GTX's.
Had 650W and 65Amps over the two rails, and slotted in to 2x5.5 slots
I went the whole hog and got a Toughpower 12oow PSU for my 480's in SLI and its just great on my 580s now. I think out of all the things you need a good quality powerful PSU, especially if you're going to have SLI 580's!
An 850w PSU should be ok with no overclocks..sorry to hijack but will a corsair ax850w(70a) be fine for 580sli? im looking at the same rig as you but with just 1 msi 580 for now and a cheaper psu.so i would have to power a 4.8GHZ OC too and 1 HDD
Thanks..
That very cheap for a 1000watt Modular PSU..![]()
Guess you missed my other thread and link to it (post 53Would this Antec 900 watt PSU be any good for the OP?
