Hey. I know so little about TV's that I'm considering buying an off the shelf one on the high street, but I suspect this is not the best approach to take. Specifically I think they'll lie through their teeth and I wont realise until later. So buying from a shop would be good, buying based on the salesmans recommendation not so much.
I'm looking to replace a terrible 26" Goodmans TV with something slightly larger and less crap. I imagine 720p is significantly cheaper than 1080p, so I've been looking at 32" 720p screens. I'm not convinced I'll be able to tell the difference from 3m away.
It would be convenient for it to offer a vga input but this is not essential. I've no interest in freeview, but it seems to be compulsory. For that matter I've no use for a built in tuner either, I'm merely assuming that TVs are cheaper than monitors.
Screen size is flexible, budget is flexible. Second hand would be fine too for that matter. I'd like it to last at least a couple of years, so 2/3 year warranty would be nice. Where should I be looking?
Many thanks
Many thanks
