Processor and other things...
14 Jan 2011
East Yorkshire
Hi guys...my first post here ( hope it's in the right forum)!
I'm putting together my first self build PC and need a bit of advice ..particularly on the processor. I've been looking at the Intel lineup and it looks like the Intel i5 2400 (Sandy Bridge) seems to give the best bang for your bucks.
I want to build an all-purpose machine ( on a bit of a budget) which will cope with the latest offerings from Adobe Photoshop et al to do some fairly heavy image editing, general office duties, not to mention a bit of decent gaming, when I eventually have the time.
The specs I have in mind are:
CPU - i5 2400 ( Sandy Bridge)
RAM - 6Gb DDR 3 1333
HDD = 1 Tb x 2
Optical Drives x 2 ( BlueRay reader/DVD writer + DVD reader)
Card Reader
Decent mid-range graphics card.
On top of this I need a decent PSU...
So can you give your opinions on the i5 2400 SB or whether there are better value processors for my needs. Also which PSU ( UK voltage) do you suggest to cope with the specs I'm putting together?
Finally, can you suggest a mid level gaming graphics card that will do a decent job without breaking the bank?
Thanks ..
Joe
You want to be buying 4 or 8gb ram with sandy bridge ( dual channel)
Maybe dont get the second optical drive aswell and get the i5 2500k much more potential with the overclocking.
you might need to give a rough budget, and i'm sure stulid, RJC and the rest of gang wont be long speccing you summat decent:p
Thanks for the reply...
I figured maybe around £570 would cover most of the bits I'd need except the ATX case and graphics card.
Does that sound reasonable?
Yep...I meant to say 2500 rather than 2400 as there isn't much difference in price for the extra performance! Do you think it a good choice? An extra couple of Gb of RAM won't be a deal breaker, so I'll certainly take your advice on that one!
I noticed in your first post you missed out a motherboard, have you already got one?
Il just go and play with that budget for a couple of minutes :)
I would say the 2500k chip is worth the extra cost but 195 is high. However if your not getting a k chip then i would buy a 2500 over a 2400.
Get a 5850 or wait for gtx 560 on mon or tues. Id get a 600w psu from silverstone. Xfx. Corsair. Ocz. Dont cheap out on psu.
Your basketProduct Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £194.99
(£162.49) £194.99
(£162.49)
Foxconn P67A-S Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £99.98
(£83.32) £99.98
(£83.32)
XFX Pro 650W Core Edition Power Supply £66.37
(£55.31) £66.37
(£55.31)
Samsung SH-B123L/BSBP 12x BluRay ROM DVDRW DL & RAM Lightscribe SATAII Optical Drive - OEM Black £49.99
(£41.66) £49.99
(£41.66)
Antec 100 One Hundred Ultimate Gaming Case - Black £44.99
(£37.49) £44.99
(£37.49)
GeIL 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz VALUE PLUS Dual Channel (GVP34GB1600C9DC) £33.98
(£28.32) £33.98
(£28.32)
Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS) £31.99
(£26.66) £63.98
(£53.32)
Samsung SH-D163C/BEBE SATA 16x DVD-ROM (Black) - OEM £9.98
(£8.32) £9.98
(£8.32)
Sub Total : £470.23
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £10.50
VAT is being charged at 20.00% VAT : £96.15
Total : £576.88
just add a graphics card.
you got two 500Gb drives and a blue-ray player/dvd burner and a dvd rom drive.
the motherboard comes with two sata cables, so add another two to the list - http://www.overclockers.co.uk/showproduct.php?prodid=CB-036-OK&groupid=1929&catid=1928&subcat=
Lol i read that as 570 with a graphics card. +1 for stulids build.
If you didnt add the second optical drive you could probably get your 2 x 1tb hdd's.
(£162.49) £194.99
(£162.49)
(£83.32) £99.98
(£83.32)
(£55.31) £66.37
(£55.31)
(£41.66) £49.99
(£41.66)
(£37.49) £44.99
(£37.49)
(£28.32) £33.98
(£28.32)
(£26.66) £63.98
(£53.32)
(£8.32) £9.98
(£8.32)
Sub Total : £470.23
DPD Next Day Parcel
Total : £576.88
Well I wasn't far out LOL.
Regarding a multi-card reader...it's a must have, so...any suggestions of one that is quick or are they all more or less the same?
It's certainly a good spec for the money...I need two optical drives ( one reader) so that I can copy without wasting time putting them in and out while image editing. I don't mind a small increase in budget to get the extra 1Tb HDD's.
fine.
(£162.49) £194.99
(£162.49)
(£83.32) £99.98
(£83.32)
(£55.31) £66.37
(£55.31)
(£41.66) £49.99
(£41.66)
(£37.49) £44.99
(£37.49)
Seagate Barracuda 7200.12 1TB SATA-II 32MB Cache - OEM (ST31000528AS) £40.99
(£34.16) £81.98
(£68.32)
(£28.32) £33.98
(£28.32)
(£8.32) £9.98
(£8.32)
Sub Total : £485.23
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £99.15
Total : £594.88
I suspect the latest ones will just be regular SATA ?
no idea, could be usb and connects to motherboards internal usb port.
Theres the i7 2600k i'm not sure whether the extra cost is worth it though and the i5 2500k should wipe the floor with i7 920,930,950 and some bench's show it contending with the very top end once its been overclocked.
i7 2600k is only 55 pounds more stulid?
One question I have been meaning to ask you guys for which you may have an answer...
The OS system would obviously be Windows 7 with the new build BUT, I'd prefer to actually use good old Windows XP Professional ( which I already have) as, I have some legacy software ( for my cameras ) which apparently doesn't work with Windows 7 for some reason.
Would Windows XP Pro work with the new set-up and if so, is it possible to set up and use a dual OS selected at boot-up? ( ie: W7 or XP pro)
