- 11 Jan 2011
Hi, im looking for a monitor to go with my new build. 22" to 24" budget of around £250/£300.
what would you recommend?
Most 24 inch monitors are around £150 these days, but if you want to spend £300, get yourself a 3D vision ready 120 hz one:
http://www.overclockers.co.uk/showproduct.php?prodid=MO-043-BQ&groupid=17&catid=1851&subcat=
Its not in stock though.
the samsung has HDMI input and funnily enough optical and 3.5mm audio outputs for sending the HDMI audio from a connected games console onwards.
the cheaper BenQ above doesn't have a HDMI input.
