Seems fine, whats the problem??
Windy guns often have trouble removing bolts when torqued up, you should slacken them with a breaker first or use a mught bigger gun.
It's very hard to tell from that Video but it looked to me right at the end the way the torque moved your hand that your gun is set to tighten and not loosen, put it in reverse and try again![]()
