A H70 is not good value for money, a decent air cooling solution will more than suffice.
The Titan I linked will save even more money!
Have you changed the RAM to the Geil too? Really do recommend this.
Well first off the cpu cooler is overkill. Have a browse thru the overclocking and cooling section, the 'k' chips are highly efficient and oc without serious cooling needed. Not sure if you really need xfire 6950's. I'd look at getting 1 first of all and possibly flashing it to a 6970 and see what performance is like.
As do I. See post #2![]()
THIS RAM will fit under any cooler and still overclock very well.
If you swapped a 120GB SSD out for a Crucial C300 64GB SSD (for OS and fav. programs) and then added a fast 1TB for storage, you could save a chunk of money.
