AM3 SLI Upgrade help
Permabanned
22 Dec 2010
Cambridgeshire
Current spec is in my sig, thinking of going sli though with two 450's.
Can anyone spec me a AM3 board SLI compatible in the £50-£60 range.
Or would it be just as beneficial to get a 1gb 460?
Whats your budget for the extra benefits?
Oops 50 - 60 soz for you.
You say a budget and are happy with a 460? Buy it!
:Edit:
Sorry i think the post needs more thinking as nothing has been posted.
No AMD boards do SLi, unless you get one with a Lucid chip. But multi-GPU scaling on Lucid Hydra is about 20% worse compared to SLi.
I would get the 460 1gb as that's the only option for you. Personally I would save up a few more and see how the 560 does.
:Edit:
I honestly cannot understand what you're talking about
Thanks for the advice.
Didn't know AMD couldn't do sli. Should have gone the ATI route initially then. Oh well.
Ill save a few extra pennies and get the 460.
I game at 1360 x 768 59hz.
Just looking for all round general performance increase to be honest.
But now thinking about it, ill have to do a pretty hefty upgrade to get it all setup. New mobo, gpu and psu.
Reckon i'll probably go for a 460 or 5850 then.
