Any tips for a Asus Sabretooth tuf?
3 Jul 2006
St. Neots
I am helping a frield o/c his i7 950 on a Asus Sabretooth X58 tuf.
Not being a i7 user I am not familier with the new bios and settings to safely and slowly oc these boards.
Any tips on what I need to look at and what I should be changing?
Many thanks and stay Phunky :)
Just put the qpi to 1.3v
20x multi
200blck
=4.0ghz
Vcore at 1.3v then work your way up or down from there.
If you need above 1.3v for your vcore for 4.0ghz maby bump the nb voltage abit
Ah, my attempt failed as did not keep the ram speed low enough. Hit 4ghz 1.3v but not stable in prime.
Think ram timings are to tight as set to 8-8-8-20 when should be 9-9-9-24!
Wife kicked me off for now so back to STD settings for him!!
