ocuk Overclocked sandy bridge Bundles
I guess most people bought separate items, but you cant go wrong with either of the two bundles, both motherboards have the same features, it probably comes down to looks.
separate items.... ok well its good for me i work a lot and would be good not to spend to much time overclocking. as the bundles are overclocked thought it was good :) :confused:
Your basketProduct Name Qty Price Line Total
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor £194.99
(£162.49) £194.99
(£162.49)
Gigabyte P67A-UD4 Intel P67 (Socket 1155) DDR3 Motherboard - (Sandybridge) £149.98
(£124.98) £149.98
(£124.98)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £49.99
(£41.66) £49.99
(£41.66)
Corsair A50 High-Performance CPU Cooler (Socket AM2/AM3/LGA775/LGA1155/LGA1156/LGA1366) £30.62
(£25.52) £30.62
(£25.52)
Arctic Silver 5 Thermal Compound (3.5g) £6.73
(£5.61) £6.73
(£5.61)
Sub Total : £360.26
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £9.50
VAT is being charged at 20.00% VAT : £73.95
Total : £443.71
VS
"Radon Torosaur" Intel Core i5 2500K 3.30GHz @ 4.40GHz Overclocked Bundle - Gigabyte £459.98
(£383.32) £459.98
(£383.32)
Sub Total : £383.32
DPD Next Day Parcel
VAT is being charged at 20.00% VAT : £78.56
Total : £471.38
If you will be happy with 4.4GHz, and will never touch it, then I'd be inclined to spend the extra £30 if you are not confident with the overclocking.
That said, it isn't a difficult affair; On the Asus board, its just a case of setting Overclocking to manual, BCLK to 100, Turbo to all cores with a multiplier of 44 (For 4.4GHz), PLL Overvolt to on, and your memory to whatever the specifications state.
At 4.4GHz, the Asus board should do a good job of choosing a voltage for you, but most people seem to be doing 4.4GHz at around 1.25 - 1.3v - some even less!
yes would prob be happy with that :) ..... have got a q6600 at 2.4 at mo and have not been able to overclock as have **** motherboard. i will be looking at getting water cooling later on in year so will prob try getting more out 2500k then
wow £30 more just to have it pre overclocked to 4.4ghz with a warranty!
Thats a bloody good deal! Time to update my spec...
i was thinking of getin SB bundle but i mainly game and abit of encoding not worth it to me at the mo for the setup i have....
