The Gingerbread lock screen animation really is a sight to behold, its awesome![]()
Can't play Angry Birds because of an absolutley humongous advert that appears on the screen. As i've rooted my phone i've tried AdFree but it doesn't always remove it
Highly irritating!!
Guys,
can you pleae explain in a easy way how to install CyanogenMod on DHD ?
I downloaded CyanogenMod recovery, ROM itself...but...
how do I install CyanogenMod recovery ? where do I copy all the files ? etc etc.
thanks
Everything you need is in Kanifee's decent guide here - http://forums.overclockers.co.uk/showpost.php?p=18229964&postcount=3047
It may look like a lot of hassle but it wont take you long and I can confirm it works perfectly.
Give it another reboot, should work. I take it the phone connected fine before hand?
Edit
Don't reboot, power off fully then power on again, remove the battery it you feel the need
phone looks to be fine ( rang tmobile CS)
will power off now...
T-Mobile CS wont/cant help you.
TMobile won't be able to help you, flashing invalidates your warranty.
i was just checking if phone works u silly sausages![]()
but still no luck with wifi![]()
How dare you call me a sausage! I have never been so insulted in all my life.![]()
