Drop CPU-NB multiplier to 8x and HT link to 1600. Maybe consider taking both lower. That might buy some more headroom. CPU-NB multiplier is just like your CPU multiplier. The speed is HTT (or FSB in old money) times multiplier hence 10x250 gives 2500 MHz. Stock is 2000. While you're finding your CPU's highest frequency keep CPU-NB frequency at stock.
HT link frequency can never actually be faster than the CPU-NB speed. Just remember that when you overclock the bus, this raises the quoted HT link speed by the same percentage. So at 250 bus (+50%) a 2000mhz HT link means 2500mhz.
Once you have found a stable CPU core speed, then try raising CPU-NB speed. If you hit a wall try raising the CPU-NB voltage slightly. If an extra 50-100mv doesn't help you've probably found the CPU-NB limit. Once you've found the CPU-NB speed then try gradually raising HT link to match. HT link is the last priority as it gives the least performance benefit.
