How do YOU Battle Dust? We all hate dust...
My mate has a framing gun... i use the air compresser from that on my PC in the weekend... worked a treat... no more dust... just dont put it in ya mouth :D
£25 works wonders powerful enough with a small nozzle attached.
I heard postive air pressure is one way to avoid dust as long as you have good filters on all the intake fans.
Personally I just give things a little blow and brush with a small paint brush, and wipe all the non electrical surfaces over with baby wipes. My case always looks pretty clean. :)
I've also found that ionisers reduce the amount of airborne dust. Putting one the other side of the room helps. More dust falls (or sticks to surfaces) away from your PC.
My pc is dust free (thanks to a big arse air compressor my old man had) but some of the components still have a layer of dust on them that even at close range the air compressor wont shift :(
My Antec P182 with just two dust filters keeps my PC dust free, and I hardly ever hoover my room.
Wish I could say the same about my P182 :(
p.s. the link about positive airflow was great. Goiing to do myself some fan modification me thinks!
