*****Mega Monday Deals - Truly Great Deals inside!*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Some truly great deals here for you guys to sink your teeth into:-
EVGA GeForce GTX 580 "Black OPS" 1536MB GDDR5 PCI-Express Graphics Card @ £455.99 inc VAT
The world's fastest GPU has arrived with the NVIDIA GeForce GTX 580. Experience blockbuster games like Call of Duty®: Black Ops and Tom Clancy's H.A.W.X® 2 in their full glory with everything cranked to the max. Not only does the NVIDIA GeForce GTX 580 rip through the latest games, it also runs quieter than the previous generation. And as you have come to expect from the GeForce GTX GPU, the GTX 580 packs support for all the premium GTX gaming technologies such as NVIDIA Surround, 3D Vision, PhysX and SLI. With all these features and more, it is easy to see how the NVIDIA GeForce GTX 580 obliterates the competition.
Features:-
- Core Clock: 797MHz (Fermi GF110)
- 64 TMUs (GTX 480 had 60 TMUs)
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1536MB GDDR5
- Memory Clock: 4050MHz (Effective)
- Memory Interface: 384-Bit
- Processing Cores: 512
- Shader Clock: 1594MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption compared to GTX 480, only 244 watts
- Warranty: 2 years standard warranty , and once product is registered with EVGA , product will receive full 10 years warranty
Was [£479.99] Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 Direct CU TOP 768MB GDDR5 PCI-Express Graphics Card @ £109.99 inc VAT
Built from the ground up for DirectX 11, GeForce GTX 460 delivers the ultimate next generation gaming experience. With up to 4x the DirectX 11 tessellation performance of the competition, GTX 460 packs highly detailed visuals into your games - without sacrificing high frame rates. And with NVIDIA 3D Vision, PhysX, and CUDA technologies, GeForce GTX 460 powers all the incredibly realistic effects that your games can throw its way.
- Exclusive Voltage Tweak Technology
- Core Clock: 700MHz
- Memory: 768MB GDDR5
- Memory Clock: 3680MHz (Effective)
- Memory Interface: 192-Bit
- Processing Cores: 336
- Shader Clock: 1400MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was [£129.99] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Asus GeForce GTX 460 1024MB DirectCU TOP GDDR5 PCI-Express Graphics Card @ £149.99 inc VAT
- ASUS Exclusive DirectCU Thermal Solution: Three 8mm flattened copper heat-pipes contact GPU directly and reach up to 20% COOLER than generic GeForce GTX460
- Over-clocked with 775 MHz engine clock for reaching 115% performance
- ASUS Exclusive Voltage Tweak Technology for up to 50% performance
- Core Clock: 775MHz
- Memory: 1024MB GDDR5
- Memory Clock: 4000MHz (Effective)
- Memory Interface: 256-Bit
- Shader Clock: 1550MHz
- SLI Ready
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- Warranty: 3 Years
Was [£169.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Gigabyte M6900 Precision Gaming Mouse (GM-M6900) @ £9.98 inc VAT
With a gold plated USB connector and surgically precise 3200DPI optical sensor, you will be on top performance in every game. Never slip with gaming-grade rubber to always stay in control. If you are looking for a gaming mouse which does it all, look no further.
- Gold-plated USB connector
- 3200DPI precise optical sensor
- 30G acceleration ensures the best performance during rapid movements
- On-the-fly DPI switching with 3 stage red LED light indicator
- Gaming-grade rubber provides a non-slip grip
Was [£19.99] Inc. VAT
Only £9.98 inc VAT.
ORDER NOW
HIS Solar Rechargeable LED Flashlight @ £4.99 inc VAT
This great torch is not only powerful as it features 5 superbright LED's but it also requires no batteries as it charges itself using solar power.
Features:-
- Body material: Aluminum
- Solar Panel: mono or multi-crystalline
- 5pcs Super bright LEDs
- Product Size: 123×24mm
Was [£9.99] Inc. VAT
Only £4.99 inc VAT.
ORDER NOW
Intel 8GB USB 2.0 Flash Drive @ £7.99 inc VAT
Intel has always provided the ultimate cost effective mobile storage solution for people on the go. Working on a presentation, a document or e-mails and need to take them with you? No problem! Want to share new MP3 files or digital pictures with your friends? It is really easy! Simply copy the files onto Intel USB Pen and take them with you. To access your data, simply plug Intel USB Pen into any PC or Mac - without the need for software drivers, bulky cables or adapters. Also ideal for downloading films onto for watching on USB compatible TV sets.
- Save, access and share data with colleagues and friends
- Slimline design allows direct placement next to other USB devices
- Easy installation, no drivers needed, USB port bus powered
- Compatible with PC, notebook and Mac allowing cross platform file sharing
- Ideal for storing and sharing digital pictures, music files, text files, spreadsheets & presentations
- Dimensions: (WxDxL) 18x10x51mm
Only £7.99 inc VAT.
ORDER NOW
Intel 16GB USB 2.0 Flash Drive @ £14.99 inc VAT
- Dimensions: (LxWxD) 67x19x9mm
Only £14.99 inc VAT.
ORDER NOW
Crucial RealSSD C300 64GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC064MAG-1G1) @ £89.99 inc VAT
The new 2.5" Crucial RealSSD C300 drive offers mobile and desktop users scorching-fast read speeds of up to 355MB/s. And because it has no moving parts, you will also enjoy a quieter, cooler, and more durable storage solution. Designed with high-speed synchronous MLC NAND, advanced controller technology, optimized NAND management and the new SATA 6Gb/s interface, these drives dramatically improve data transfers for bandwidth-demanding applications like audio and video. The improvement in boot time and application load times push performance to new levels at the desktop too. You will experience improvement across a variety of common tasks such as viewing and editing photos, video, music and other media, gaming, communications, productivity and security.
- Capacity: 64GB
- Cache: 128MB
- Controller: Marvell 88SS9174
- Read: Up to 355MB/sec
- Write: Up to 70MB/sec
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA 6Gbps
- Low Power Consumption
- Shock Resistant
- TRIM Support (Requires Windows 7)
- Warranty: 3 Years
Was [£101.99] Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Crucial RealSSD C300 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC128MAG-1G1) @ £185.99 inc VAT
- Capacity: 128GB
- Cache: 128MB
- Write: Up to 140MB/sec
- Shock Resistant
- Warranty: 3 Years
Was [£209.99] Inc. VAT
Only £185.99 inc VAT.
ORDER NOW
Crucial RealSSD C300 256GB 2.5" SATA 6Gb/s Solid State Hard Drive (CTFDDAC256MAG-1G1) @ £369.98 inc VAT
- Capacity: 256GB
- Cache: 128MB
- Write: Up to 215MB/sec
- Shock Resistant
- Warranty: 3 Years
Was [£374.99] Inc. VAT
Only £369.98 inc VAT.
ORDER NOW
As you can see these are some stunning prices, if not the best in the UK, deals certainly not too miss out on, so check them out. :)
P.S. Tomorrow we see the launch of a new fantastic value/performance graphics card for just £200, so be sure to check the site tomorrow as well. :)
I am not trolling, but what is the purpose of a Black Ops Edition GTX580 when that game can run smoothly with everything maxed out pretty much on a gts 450...
Its all about marketing......
Just buy regular SC version, however in this case its cheaper on this offer, so your infact getting it cheaper. :D
Agreed...just bought one...:D
:D Nice one. There's not much I can say to that! :)
You might like to let me / us know what its like. My Deathadder broke recently and I'm using a stand in mouse, the OCZ Equalizer which is ok though I'd prefer to get back to using an optical again.
You might like to let me / us know what its like. My Deathadder broke recently and I'm using a stand in mouse, the OCZ Equaliser which is ok though I'd prefer to get back to using an optical again.
At first i was abit sceptical but did a google review search and found 2 reviews, both of them said that it was a quality piece of kit at a bargain price at £20, so for a tenner, i thought it was a no brainer...seeing as my trusty old Logitech Mx500 is on its last legs after 7yrs...as far as im concerned i've saved £20 to put towards a new 560 GPU, as i was going to get the £30 MX518 mouse, as a replacement...
http://www.vortez.co.uk/articles_pages/gigabyte_m6900_m6980_review,1.html
Thanks for the link. It's a nice looking piece of kit, happy fraggin'. :) Btw - I can vouch for the thumb grooves on a mouse, the one I'm using at the mo has that and it does make for comfortable use.
Must say that mouse is looking rather tempting, shape reminds me a bit of the oldschool logitech mouseman wheel which I loved. Although I'm using a £60 mouse (Steelseries Xai) at the moment so I'd feel bad replacing it after only about a year!
I can recommend the Crucial RealSSD C300, my bedroom MC has one of these in it, and It's superb. If like me, you have a passive networked MC then chuck that noisy hard drive in the bin and get yourself one of these little crackers, I guarantee you won't be disapointed.
