~~~~~Gainward GTX 570 Phantoms IN STOCK!~~~~~
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We have in stock right now the incredibly rare Gainward GTX 570 Phantom which has a very impressive cooler design. :D
Gainward GeForce GTX 570 Phantom 1280MB GDDR5 PCI-Express Graphics Card @ £309.98 inc VAT
With explosive performance and an innovative thermal design, NVIDIA® GeForce® GTX 570 rips through the latest games like World of WarCraft®: Cataclysm, Call of Duty: Black Ops, and Tom Clancy's H.A.W.X.® 2 with quiet operation. As you've come to expect from a GeForce GTX GPU, GTX 570 packs support for all the premium GTX gaming technologies such as DirectX 11, NVIDIA® Surround, 3D Vision™, PhysX®, and SLI®. GeForce GTX 570 - arm yourself for battle.
Instead of fans on its obverse side blowing air onto the PCB, there are three fans on its reverse side, drawing air from the aluminum fin array, and onto the PCB. The PCB also seems to be a non-reference design.
Features:-
- Core Clock: 750MHz
- Innovative thermal design: Vapour Chamber (Quieter than previous generation)
- Memory: 1280MB GDDR5
- Memory Clock: 3900MHz (Effective)
- Memory Interface: 320-Bit
- Processing Cores: 480
- Shader Clock: 1500MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: 2x Dual-Link DVI-I & 1x Mini-HDMI 1.4a (Includes HDMI & VGA Adapters)
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Warranty: 2 years
Only £309.98 inc VAT.
ORDER NOW
Why would you buy this card if you were planning on putting an aftermarket/waterblock on it? :confused:
i swap back & forward between water cooling and air cooling...
Because i don't always have an extra £140 spare to pay for two waterblocks at the same time as buying my GPU cards ;)
