In the first year of ownership, you should be able to go through the shop you bought it from. Try that.
I doubt they would know. The clock speed is dependent on the software you used, e.g. if I was to overclock using Afterburner and then decided to uninstall it, the overclock settings wouldn't be saved so the card would go back to stock speeds. So if the shop was to test it, they wouldn't know that you overclocked it.
Well then the only reason the shop would have to deny me a replacement is because I signed up for the warranty late then?
Zotac says you only get your warranty if you register your product within 2 weeks and I only did this after 4 weeks.
Done mine the day I received them
thanks Craig, that sounds great.
So all I need to do is fill out the RMA form, process the request with technical support and send it off, when they get it, they should send me a replacement?
Will they replace it even though I'm missing one of the 2 manuals and don't have the 1 adapter it came with any more?
