- 3 Jun 2005
- West Sussex
omg what happened to the thread? All the sensible advice has been deleted and we are talking classic/weekend show cars.
Never mind. For 4k you could buy a blinding mini. Remove the engine and get an MG metro lump. Get the head skimmed and ported. For road I would use a Kent 276 cam. Unless you want to cut the bilkhead keep the 1 3/4in SU Carb rather than than a webber side draft. A Howley inlet is great as it is water heated and stops icing in winter. Use an LCB manifold an exhaust of your choice (RC40's are great).
Either a 10 or 13 row oil cooler is great and make sure you fit a central oil pick up for hard cornering. It is also worth having the crankshaft cross drilled and wedge as well as a centre main strap to avoid breakage. Remember if you do replace the engine for an MG Metro lump and box that the Diff may cause problems on wheels other than 13inch.
Do all this and your mini might perform as good as a standard Punto Sporting. I use to build custom Min's and they are great fun. But I would never use one for day to day use.
You have changed from 'oh no not again' to the voice of reason. Most of the time
