Here you go, default Crysisanything else?
Personally I deem a 5850 running crysis at 30fps with full settings, a pretty capable card at 'maxing' it.
You said a 5770 could max it though.
So if I have a 120hz monitor, but only getting a lowly 90fps 'maxed', I'm still not maxing it?
haha, so now I've posted benchmark evidence of my 5850 getting 30fps average - which earlier was disputed and challenged - it has now shifted back to "but you said a 5770 could also max it!"
Deary me.
not optimal fps for your monitor imo better than a 60fps on a 60hz though but i would still consider 60fps on a 60hz maxed out
Didn't max it at all. That's not default Crysis at all, what happens if you leave time of day blank and what happened to the ice level?Here you go, default Crysisanything else?
I never said anything about your 5850, I challenged your post that said a 5770 could max it, which it cant.
For the record, your 5850 cant max it either, 23 min fps is by no means maxing it.
So if you're going by min' fps, rather than average, that means until we have cards that get no less than a 60fps minimum then we can't be maxing crysis - or any game for that matter.
However that will only really make sense when we all have monitors that are 120hz+ so that refresh rates are higher than 60.
Your logic has so many holes in it![]()
The fact that you think because your 580 drops to 40fps means it isn't maxing out the game is just beyond idiotic. I'll just leave it at that.
Deary me.
20fps
wait wait.......if I have a 60hz monitor and I'm getting 59.562fps, am i maxing it and does it get rounded up?
How juvenile.
"I'll leave it at that", being I'm no longer willing to discuss what fps conditions 'maxing' it out has.
im not sure why your so defensive about agueing this unbelievably mute point....the 5850 is better then the 5770 last time i checked and i would hardly call that maxing out. yes you may have an average playable 30fps, but the min is in the early 20s! that is no way a playable game..
