Yep. Matching SIMMs and everything. 2x8MB, 2x32MB.
That's an amazing amount of EDO memory
I think I only had 64MB when I had a P2-450.
Recently - A Oven and a hoover!!
 The other one is all fine, but it won't stand up straight and the bit you hold falls down to the ground. Something has snapped out of it but I can't work out how to take it apart yet from my 2 minute "lets have a quick look love" after she broke it.
This is a thread dedicated to people who might like to explore and take matters into their own hands. Maybe it's to fix or repair or bodge something that has annoyed you when it stopped working just outside of warranty? Or maybe you modified a piece of hardware? Maybe you wanted to fix something on the cheap? It can be anything really but I thought I would try to keep the theme on electronics or powered items.
Recently took my Tosh 32" lcd tv apart as it wouldnt switch on... After googling around found the fault, ordered the part for £6 and replaced the part. The tv is now working again.
 I have a 46inch, think it is the 46XV635DB. cheersSome 17" LCD screen, inverter packed up so I replaced it with one from a CCFL case lighting kit, seemed to work. Extra bodge marks for using gaffer tape to hold the case together...
That's what I was saying above about my TV is about to do this. Also a Tosh. Where did you get the part fella? Any info and methods that save me researching it myself will be greatly appreciated to save time.I have a 46inch, think it is the 46XV635DB. cheers
Did exactly the same, monitor eating through inverters at £10 a pop, so replaced the tubes too. I only had blue ones though
 I've been outbodged! You could probably throw some white ones in at some point, but I think that the blue has a certain goofieness to it...Today I've done some more bodging, managed to hack open a few laptop battery packs and am using the cells to make a portable sound system...
Nice!I've been outbodged! You could probably throw some white ones in at some point, but I think that the blue has a certain goofieness to it...
