Whoa, those last few pics are HUGE!
yeah i had some close calls with that fan, i seem to remember mounting one without the easy remove frame once to gain a little space, and possibly on the wrong side of the frame work tooI totally agree that the fan in the middle of the bottom compartment has always been a pain even when I had a much smaller PSU. Cables were always in danger of hitting the blades too (due, of course, to my lack of cable management).
I'm going for an EK GPU full cover block i think, and that matches the MIPS blocks i have ordered but not paid for yet (mondays priority job after car warranty stuff - need to make a claim for repairsMy original shopping list included Dominator GT RAM and I wasn't sure whether the MIPS was suitable (yes I was aware of it). However the Dominator GTs seemed to be out of stock everywhere and no one seemed to know when they would be in stock and since I was doing this build over Xmas I downgraded to the Dominator RAM. My plan was to see how bad the AirFlow fans were and to take it from there. I also thought (wrongly for some reason) that I could slow them down with my BigNG. Furthermore I must confess to being quite a big EK fan and all their products I've used to date are top notch, so I'm still leaning towards the EK ones.
I'm going for an EK GPU full cover block i think, and that matches the MIPS blocks i have ordered but not paid for yet (mondays priority job after car warranty stuff - need to make a claim for repairs)
The MIPs blocks are good quality, just hard to get hold of here, and are expensive! they are compatible with Dominators as well as GT's and also mushkin i think, they do about 3 different ones, the Domiantor GT's i ordered came in damaged and the place i ordered from are having to wait for Corsair in the Netherlands to ship new units![]()
... i'm not sure if the EK-RAM is available in copper, all i see is nickel, or if it's suitable for 4 sticks of RAM, but yes it is basically the same thing.
hmmm, ok i didn't explain myself too well there did i
...or if it's suitable for 4 sticks of RAM, but yes it is basically the same thing.
^^ can't see how much space there is between the desk there and the fans but there is enough for decent airflow yeah? Don't want a silly thing like that to impeed cooling do ya![]()
Fair play on tis i dont think i would have attempted the rad fix but it seems to of worked really well. How are you finding braiding as i havent ever done it and i think i might on my rebuild.
looking very nice.
i cant really tell from that bottom pic, but it might be that you are not allowing enough braid to be held by the heatshrink
... i have in the past used sticky electrical tape, wrapped it first, then unwrapped it, then sleeved it with the heat-shrink, and when it is shrunk down, the sticky residue left behind by the electrical tape is enough to ensure it doesn't slide out. !
Glad you got your pump surging sorted
how do you find the "silver KillCoil" .... i was contemplating this myself, are there any situations when it should not be used ? and best place to insert it in the loop ?
Yeah i know what you mean, it's in the back of your mind now, nigglng at you !I hope so too. I am not 100% convinced that the new firmware entirely fixes it. I have heard a few noises that may have been the pump, but they are now few and far between. Of course those noises could have been the central heating pump which is in the airing cupboard in te same room.
LOL, nah i wouldn't recommend drinking itThis is my first time using a kill coil so I hope I have put it in a good place. I don't actually know if it is working, but there's no obvious algae build up. Dunno how I tell if there's anything else lurking in the water - I am not about to drink it to find out!
I think basically if you don't start getting any furry build up or algae then it's doing fine
