Hi Rasta.
Firstly I must apologies for being selfish and not posting my experiences, as a fellow Citiz owner
I just this moment tested this issue by running the Citiz 4 times by pressing Lungo and 4 times espresso.
I did not lift the lever until the last time, which I could see deposited a fair amount of water into the drip base when I looked inside (you can see the capsule holder retracting back and dumping the water into the drip tray through the capsule hole).
The drip tray was probably a millimeter (if that) high of water.
I think it primarily depends on whether you lift the lever or not. The best test is to probably fill your water tank up to the brim and just keep pressing the espresso button without lifting the lever at all and see how much water gets deposited.
If there is little to no water, then I think you have nothing to worry about.
Also dont forget condensation will eventually form and when it cools will most likely also add to the drip tray. Just a thought
Let us know how you get on. When I get a spare moment I might actually do the same test!
Just out of interest how do they give you the money off? Is it a code or does it just discount your order or something?
