So, trying my first overclock now I've read a bit more after last weeks boot-fail.
Anyway running a Q6600 on a P5N32-E SLI and am stable at 2677MHz at the moment. One thing I've noticed is when I set the voltage manually in the BIOS (currently 1.3125V) it doesn't show this in CPU-Z or CoreTemp.
What CPU-Z and CT show when set to 3.125V are:
As you can see the CPU-Z voltage fluctuates between these 2 values but the CT stays at 1.275 which is stock for this CPU. There's quite a difference between the 2 and when loaded the CPU-Z value falls to around 1.200V.
Is this what's meant to happen? I'm confused.
Cheers
G
Cheers
G
