5 pounds to anyone who can find me..
3 Jul 2005
5 pounds of sand that is.. Seriously if anyone could find this I would be very grateful.
Basically im in need of a sucker type product ie something which could be used to climb a metal wall or windows and preferably have a metre long pole attached to it.
There is litterally zero information on the web and I dont know what I should search for. thank you thank you
what do you mean by the pole part like a plumbing plunger with a meter long broom handle stuck on it coming out at 90 degrees from the wall, or a plunger with a hinge then the handle lying parallel to the wall?
how much weight does it need to support and if that pole is horizontal that's going to be a lot of leverage prying it off the wall.
basically, something like what this man uses in this video:
but it wont be holding a person, itll be holding a flag so would need a pole attached.
I do believe James Bond had something like this in 'You only live twice'. :eek: :p
what i mean is will the pole be sticking pout perpendicular to the wall with a weight on it?
because that's going to pry the thing off with a lot more force than say a human just hanging off it.
the triple/triangle one Hotwired posted would be good as it would stop it tilting it and breaking the seal.
I expect you mean things like these glass/sheet metal handling suckers except specially adapted for humans to use to climb up walls:
http://www.speedyhire.com/Tools-&-E...&-Roadworks/Glass-Suckers/p-1-10-20-195/#
Apparently one person at least has used suction cups to climb a shiny windowed skyscraper in America.
thank you my friend
what you need fella is a glaziers suction cup clicky clicky
unfortunatley, i don't think they come with metre long poles attached :(
cheers buddy
IF you want to see about attaching a pole to it google "car photography rig"
Might be the sort of thing you are looking for :)
