AMD board for Phenom II x2 560
22 Oct 2010
Pontefract
as title says friend wants a low cost unlock motherboard for a Phenom II x2 560 BE. he got the CPU at a very low price from the bay (£50) with a guaranteed stable X4 unlock.
must support DDR3.
Any form factor.
must work out of the box as he dose not have CPU to flash BIOS
No board can be guaranteed to unlock
Also without contacting shop you cannot be sure it will work out of the box as most people do not know which BIOS version will be getting supplied, depends on the shops stock, and tbh a lot of the time the shop itself may not know unless theyve happened to open a batch for some builds or somat
You may be best posting in customer service, dropping a webnote or giving them a ring even
when i say guaranteed unlock i mean the CPU as been unlocked to an X4 and tested with prime95 for 6hr's. I will ring customer support as you say for best chance of it working, if not he will have to buy a V low cost used sempron for flashing the bios
