AMD Radeon HD 6990 Pictured Up Close
6 Oct 2007
North West
Here's the Radeon HD 6990 up close. The HD 6990 is AMD's new dual-GPU graphics card that extends the performance leadership held by Radeon HD 5970. The pictures put rest to some speculation surrounding the cooler design. It now appears that the cooler design is similar to that of the GeForce GTX 295 single-PCB, as far as air-flow is concerned. A single long PCB holds two GPU systems on either sides, a centrally-located blower pushes air on either sides. The exhaust from one GPU is sent out of the case, while that from the other is pushed out of the card from its rear portion.
The Radeon HD 6990 uses two 40 nm Cayman GPUs, it packs a total of 3072 stream processors, and 4096 MB of memory between the two GPU systems. It also features a new kind of display output that consists of one dual-link DVI and four mini-DP 1.2. Power is drawn in from one 6-pin and an 8-pin PCIe connector. The card can pair with another of its kind for 4-GPU CrossFireX. It is expected to be released a little later in this quarter.
http://forums.techpowerup.com/showthread.php?t=139221
Not sure they they moved the fan to the middle of the card. You'd think that a fan at either end would be more efficient in exhausting the heat outside of the case instead of some of it being dumped back into the case.
Even cooling, the air would be perhaps too hot by the time it got to the second core's heatsink.
Same thing though with the other x2 cards, the 3870x2 had an aluminium heatsink and a copper heatsink, the copper one was on the second core as it was further from the fan. 4870x2 just went dual copper heatsinks. Given the length of the cards id say an additional fan would assist in geting more of the hot air out.
From what i have read today in similar articles the card is slightly smaller than a 5970. They also mention that the card in the pictures is an early prototype and that the release cards will most likely come with 2x 8 pin power connectors.
Two fans would just fight each other ;) The cooling on each core goes beyond the 3870x2 through to 5870X2 and therefore the difference between the two cores became too significant, or maybe it saves money over, over designing the cooling for the second core.
That early sample would have horrible cooling, unless it has some enormous 7 heatpipe cooler. I really really do not understand why manufacturers don't add larger 92mm fans and let them bulge out of the side slightly, like the 8800 Ultra did. Almost all cases have a few cm of horizontal room to accomodate the changes.
Its to keep within the agreed spec, but seeing that the PCIE power plugs are side on ATI should have room to fit a bigger fan.
I don't like the look of the design.
