- 14 Jul 2005
- Bristol
Don't worry, it's not mine.
I guess it's a 1.3 or something, horrible little things anyway.
My friend is having issues with the car, when it's started it'll idle fine but as soon as throttle is applied it splutters and dies. That's what I've been told, will go take a look in a bit though.
Any ideas as to what it could be? My googling has come back a bit useless really, MAF and TPS appear to cause issues, but the other way round...if you leave it to idle it'll stall, but if you throttle it stays running.
Best guess as the moment is dodgy fuel, but then why would it idle fine if that were the case?
