New Sandy Build, PSU Question, Opinions wanted.
26 Jan 2011
Hi this is my first post and my first time using the site and forum.
I will be ordering a new Pc on Friday, My budget is 800-900 , but obviously the cheaper the better.
This budget will not be including a main sata II hardrive as I already have a Samsung F1 1TB, or graphics card which I will be buying next month (either a 570 or 2x 560s,) and will be using my ati 4850 till then.
The thing I'm not sure about is the PSU, I already own A corsair TX750, but as the case I am getting has a window I want the cable management to look good.
Is it easy enough to make the cable management look clean with a standard PSU, Or would a modualr PSU be a good investment for the future.
Here is my current Spec
Also any opinions on this spec would be much appreciated, I will be mostly using it for gaming and general use (bluray, music surfing ect.)
Thanks guys
Think you might need a higher wattage on the PSU if you want to go SLI graphics, 650W is really borderline. The GTX 560 at reference speed is 200W.
I would say the 750W would be better and allow headroom.
Hiding the extra cables can be a challenge but it's not worth buying a new PSU.
The only Problem with that is if I do try and fail with The TX, then it will cost be an extra 8.50 to ship it separately.
I do see what you saying tho, hmmm..
I think the Noctua cooler is a bit overkill but it's your money. Nice choice of mobo though;)
Thanks for your suggestions, may consider the Ram, but i kinda have my heart set on the cooler for the great reviews its received giving good temps and how quiet it is.
Hmm, the main thing with the cooler is its meant to be really quiet, and yeah I heard the Motherboard is meant to be good and hopefully looks good in a black case which should be a plus.
Thanks mate
Its the BEST air cooler.
Indeed it is.
Ive decied to try my corsair TX750w first and hope i can getting it looking satisfactory.
Just want to say thanks to everyone for their comments and suggestions.
Ill proberly post some pics up next week sometime when its all built.
:cool:
