Why do people call it 'unlocking to 6970'?
1 Dec 2010
Winchester, UK
When from what I have gathered, bearing in mind my unfamiliarity, the unlocking only opens up the shaders. The actual speeds of the card need to be overclocked to 6970 speeds don't they? Which I'm relatively sure the 6950 could do anyway.
In that case, it's not really a 6970... more a 6950 OC. Or am I missing something critical?
Just a little point of curiosity.
unlocking the shaders gives it the same number as a 6970. So at that point its now a 6970 but with lower clock speeds, then you up the clock speeds to same as 6970 if not higher.
I think if I remember reading right the 6950 is originally a 6970 with locked shaders and lower clock speeds.
The unlocking you refer to means you flash the 6950 with a 6970 bios. The actual physical cards differ on only 2 counts:
1. The 6970 has an 8pin power socket and the 6950 has a 6 pin.
2. The memory chips are slightly higher specd in the 6970.
When you flash the 6950 with a 6970 it becomes a 6970 in terms of stream processors and also clock speeds...
So in essence it is a 6970... you can also get mdded 6950 bioses that simply unlock the shaders, this is what I did. And then overvolt them and overclock them...
I would recommend simply using one of the modded 6950 bioses... The 6970 bios mod can (apparently) kill cards. Voltage modding isn't really needed, if you max out ati overdrive (840mhz gpu, 20+% powertune) it will eat most games alive with the unlocked stream processors...
it is fairly simple. Techpower up has an article on it and there are numerous guys on this forum whom I sure could give you some assistance (having done it to their cards already) Easyrider, Gareth for example...
The 6950 bioses are for XFX, HIS, Sapphire and Asus cards as far as I'm aware. However they are intechangeable (I am using asus bioses on my sapphire 6950's)...
I remember my first bios flashed card, the expensive ATI 9800 pro > 9800 xt.
I missed the opportunity of the far better and earlier ATI 9500 pro > 9700 because I didnt know anything about bios flashing then.
The 6950 > 6970 flash does sound great, but I wish it was still possible to get a £150 card and unlock it to a £300 one :p
The legend of the ATI 9500 pro shall not be forgotten!
That's strange. The texture fill rate should have been slightly less.
Both the texture units and stream processors are linked to the SIMD clusters so enabling those will fully unlock the former two. But regardless, performance still ends up the same as a HD6970 when unlocked.
