Ok so im pretty much new to building, making my new build very very soon iv been told (by the honourable and esteemed overclockers forum peoples):
that theres no real point in getting the 3.3ghz phenom as the 3.2ghz is cheaper and by "adding one to the bios" they become equivalent
Also they overclock to the same speed?
Are they any advantages at all to getting the 3.3ghz over the 3.2?
Does the 3.3 overclock higher than the 3.2 does? (i should have sufficient cooling)
Also - how difficult is it to 'add one to the BIOS' - bearing in mind I am 100% new to o'clocking etc with the help of a tutorial would i be able to do it? Also is it safe and reliable?
Any suggestions/advice would be much appreciated
(I do know the i5 is a better bet but its gotta b n AMD)
Also, have similar posts on radeon 6950 v. 6970. And a SSD & SATA2 v. a SATA 3 (if u know what your doing in that region and have any suggestions there plz do look it up and drop a post)
Thanks in advance
Thanks in advance
, i also like the way it idles at room temp with stock cooler too.( max 40 when fully loaded)
