What is youre Windows Experiance Index!!
10 Jan 2011
Hello guys,
I'm a little bored and while playing around on the PC I found a little tab to update my Experiance Index, it was sitting at 5.5 before I upgraded some units, after 30 seconds it came up with a score of 7.5 is this good at the highest is 7.9 so I've been told,
Also I've been told that the index gives you youre score based on the lowest subscore so mine looks like this
Processor 7.5
Memory 7.8
Graphics 7.8
Gaming Graphics 7.8
Primary HD 7.5
I just think 7.5 overall is a bit harsh surly it should be in the middle at 7.6 or even 7.7.
so the question as it is in the title / What is youre personal Windows Experiance Index!!
its a pointless test, with zero meaning, and there has been threads before asking peeps to post up their scores.
There has to be a meaning to the test overwise why would it be a part of windows???
how can there be a meaning to it, my vapor-x 5770 reports in WEI @ 7.7, from memory. so, for example, a pair of 580 gtx's in sli at best can only be 0.2 points better, at least going by WEI.
it's absolutely pointless for hardware camparing or indexing
Your.
I have no windows experience index, as I am not running windows. I feel this means I win.
More helpfully, if your computer is capable of doing everything you've asked it to within a sufficient time period, you know it's good enough. Benchmarks wont help there, they'll only tell you that it could be quicker.
Then these forums have definately changed for the better :eek:
I was under the impression a lot of forum members bought the high end hardware for benchmark and boasting reasons.
Like the £900 extreme CPUs :D
a lot do just not on WEI. ;)
As others have said, the WEI is possibly the worst benchmark available- not least because its scores use made-up scales with artificial maximums at very low levels. All the benchmarks that stulid's posted are well-known, respected benchmarks, which actually reflect the computer's performance at whichever tasks they test.
You're quite correct, however not too many are gonna boast that they have a WEI score of 7.7 or whatever it may be. not much of a boast!!
which will be only 0.1 or 0.2 points better off than my 140 quid i5......again not much to boast about now is it ;)
WEI = Pants :p
a lot of people wont get an overall score about 5.9 due to windows not being able to go any higher for mechanical drives. so in terms of overall performance boasting, its pretty poor, but like suggested, it lets users know if aero will run ok.
try some proper benchmarking apps, then play with your setup until you get something stable with a score you are happy with.
failing that, just install some games or whatever you are using it for and see how it performs in everday use, as, in all honesty this is all that matters. benchmarking is more for stability testing in my opinion.
So is 5.9 good for a 5400rpm HDD?
