UniRoyal Rainexpert Tyres
Ive just fitted a couple of rainsport 2 tyres to my corolla tsport.
so far very good. ive done about 500miles on them on damp roads, and found them better than eagle f1's and toyo t1r's.
no wheel spin or understeer at all
obviously cant comment on the wear rate at the moment
I agree Jono 100% with you i would have expected them to last a lot longer, why they only lasted this long i have no idea.
Have you actually measured the tread depth?
I've frequenmtly thought my tyres were due for replacement but when actually measuring them they've been like 4/5mm - way off replacement.
Have you checked the tyres your self or has a garage told you that you need new tyres?
I have checked the tyres myself and there is about 2.5mm left of tred on each tyre. 3 of the tyres are not goodyear as i first thought.
They are actually Falken Ziex ze912, the other tyre is goodyear and stupidly i assumed that all my other tyres were goodyear.
Think you need to get the car checked out, as other people keep saying 6k and needing to be replaced!
Could it be when you got them fitted they actually fitted part worn tyres? Can these guys be trusted?
Yeh i agree with you Ginc the garage i used was recommend by a good friend but i won't be going back there.
Managed to get one of the local tyre fitters here to get Nexen N2000 fitted for £48 each tyre making £192 total for 4, get it done on Monday
You can get a lot better than Nexens for just a little bit more, possibly even less if you shop around.
These will be even worse than the goodyears around roundabouts!
