4 New fantastic products from Razer. Introducing the sand blasted aluminum Ironclad which razer are now making sure they cover all the areas. Soft pads, Large pads, Hard pads & Metal.
Pre-order Now
Razer Ironclad Hard Gaming Surface (RZ02-00400100-R3M1) @ £59.98 inc VAT
The Razer Ironclad gaming-grade mouse mat is engineered to bring out the most comfortable glide of today’s gaming-grade mice while retaining extraordinary tracking control. Its finely sandblasted reactive coating delivers optimal glide to both high- and low-sensitivity gamers. Built of a solid aluminum body that prevents warping, the Razer Ironclad is reinforced for strength and durability.
- Ultra-Smooth Sandblasted Surface
- Robust Unibody Construction for extra durability
- Extra-Large Mousing Area
- 2 Year Warranty
Only £59.98 inc VAT.
ORDER NOW
Razer Scarab 2.0 Gaming Surface @ £39.98 inc VAT
The Razer Scarab gaming mouse mat is the much anticipated sequel to the Razer Destructor. To create a mouse mat that is on par with the performance capabilities of today’s gaming mice the engineers at Razer revisited the Razer Destructor to improve the Razer Fractal™ surface – the core of the Razer Destructor’s dominance. The result is the enhanced Razer Fractal 2.0™ surface composition: The entire mouse mat is subdivided into very small areas, each of which displays self-similarity to its surrounding areas. This aids mice sensors to establish a highly responsive and uniform tracking. The Razer Scarab is fine-tuned to be an all-rounder, allowing you to make effortless swipes across the entire surface as well as precise movements to acquire your targets more accurately.
- Fractal 2.0™ surface coating
- Optimal performance for both laser and optical mice
- Hard mouse mat providing precise tracking
- Improved rubber base for greater stability
- Large size suited for most gaming environments: 350(W) x 250(L) x 3(H)mm
- Reinforced carrying case for optimal stowin
Only £39.98 inc VAT.
ORDER NOW
Razer Goliathus Extended Control Mouse Mat @ £34.99 inc VAT
Lab-engineered by Razer's scientists and field-validated by the biggest names in professional gaming today, the Razer Goliathus Control Edition greatly enhances the precision and tactile response of gaming-grade mice without introducing excessive, fatigue-inducing drag and premature surface degradation. Now in an extra-large size and an exclusive limited edition design, the tournament-tuned textured weave enables mice - regardless of sensor type - to register the minutest of movements, thus yielding unprecedented targeting and tracking accuracy while maintaining a perfectly controllable yet consistent glide.
- Heavily Textured Weave For Maximum Mouse Control
- Pixel-Precise Targeting And Tracking
- Optimized For All Mouse Sensitivity Settings And Sensor Types
- Extended size (920 x 294 x 4.3 mm)
- Limited Edition Design
- Rubber base for a secure grip on smooth surfaces
- Month Warranty
Only £34.99 inc VAT.
ORDER NOW
Razer Goliathus Extended Speed Mouse Mat @ £34.99 inc VAT
Engineered to exceed the exacting demands of the world's top professional gamers, the highly-adaptable Razer Goliathus Speed Edition successfully melds the full-scale speed, acceleration and razor-sharp responsiveness of hard mats with the precise control and comfort offered by uncoated soft pads. Boasting an improved iteration of Razer’s award-winning woven fiber technology, an extra-large size and an exclusive limited edition design, every inch of the Razer Goliathus Speed Edition’s durable surface is a glide-versus-resistance sweet spot, making it suitable for all mouse sensitivity setups and playstyles.
- Advanced Cloth Weave For Unbridled Speed And Effortless Control
- Pixel-Precise Targeting And Tracking;Optimized For All Mouse Sensitivity Settings And Sensor - Types;Extended size (920 x 294 x 4.3 mm)
- 6 Month Warranty
ORDER NOW
Pre-order Now
- 2 Year Warranty
ORDER NOW
ORDER NOW
- Month Warranty
ORDER NOW
- 6 Month Warranty
ORDER NOW
