Okay, I've been running my 950 at 4GHz stable for a while and decided to see if there is more to get.
I can't get past 4.2 (200*21), system keeps crashing frequently. I can't really tell what the actual vcore going to my CPU is, CPU-Z/HWmon says one value while I key in something completely different in BIOS. For example, telling BIOS to go to even 1.4 makes CPU-Z report around 1.3. Speedstep enabled, but at full load. My PSU is a Fractal Design Newton R2 1000W.
I'd like to figure out what causes this, or at least what the true vcore is.
Secondly, the GTX 580. It overclocks AWESOMELY, running at 950MHz stable. However when under load it makes a few weird noises. One being the squealing but only when running F@H. Not much to do about this - thanks nVidia!
The other noise it makes is when BOINCing, it sounds kind of like a mechanical hard drive moving the arm. It's not the fan, but something else. It does this both at default clocks and overclocked. Same cause as squealing, different symptom?
I don't have a list of my specific BIOS settings, but if anyone feels like helping me out on that front I'll get them!
Cheers
Cheers
