1GB Geil Ultra 4-4-4-12 Double Sided
2 May 2004
Does anybody know if the old Geil 1GB 4-4-4-12 DDR2 sticks are double sided or not?
Or, even better does anybody know if the warnings about putting 4 sticks of DDR2 in the Gigabyte GA-EG41MF-US2H are just warnings, or will it simply not work with 4 sticks in?
Thanks.
Warnings?
Typically people on here try to avoid using all 4 DIMMs as it adds extra stress to the memory controller meaning you tend not to be able to OC so well, this is a generalisation and not sure if theres anything specific re that board
Does Geils site not tell you the first bit?
Warnings?
No it doesn't, not that I can see.
I know about using 4 DIMMs puts more stress on things, but I'm talking about this particular motherboard.
Thanks
Well I know my old motherboard didn't accept 4 sticks of double sided RAM at the same time, you had to use single sided
