HD6850 Overclocking
22 Mar 2009
Cornwall
ok, so i have had a bit of a play and have managed to run a few benchmarks with the core clock up at 945MHz and no other settings touched, but it was not 100% stable (MSI Kombustor failed stability after a few mins). seems to be ok with core clock on 900MHz though.
have i hit the wall due to the voltage? if so whats safe increases? also, why in afterburner is the shadow clock not available, is this a setting i have missed or does the card not support it? is there any gains to be had trying to increase the cards ram clock?
could be either, could also be a lack of voltage are you upping the voltage? What is it set to when the blocks appear? ie clocks/voltage/temps?
It may also be that you've foudn the limit of your card.
voltage hasnt been change, so it starts on 900/1100 (although i just bumped the ram straight up). although reading your thread, other than benchmarking the gains dont seem worth it in gaming, or did i miss understand?
put it back to stock and played need for speed hot pursuit and fifa 11 on max settings (1920x1080) and both run smooth as, so will leave it at stock for now :)
Pushed mine straight up to 900/1100 easily on stock volts and perfectly stable. It will go further, but it's being bottlenecked at the moment anyway, so there's no need.
About half an hour on MSI Kombustor did the trick.
I have recently increased the clock to 975/1100 on 1.2V, which is also perfectly stable. It will go further, I am sure.
From my own experience and benched oc's online on the reviews, 950/1100 on 1.2 would appear the sweet spot for this card as temps etc are still ok. I've also managed 1000/1200 with a larger vcore bump though.
