Show me my options at £2000
  • Thread starter Thread starter Deleted member 651465
  • Start date Start date
All my gpu's have never died, and are still working in other pc's, your doing it wrong springs to mind.
Well that is an incredible deduction. None of your gpu's have died so you presume that because someone else's has that they must be doing something wrong. I've never had ram die, does that mean everyone else is doing something wrong too?
you said GPU's plural, meaning its happened more than once.:D what with your "experience" and all.
I'm using the OCUK Inno 3d which is runing fine and comes with 2 year warranty.
Only GPU I had fail was my 4870x2.
As with most things I think if theyre going to fail they tend to do it pretty quick, if not be DOA, not had anything fail on me outside of first few weeks and even then only one thing, had a few things DOA, but were detracting now, lol
You seem to be incapable of having anyone have a different opinion to you. Did it really hurt you so much that I suggested not spending over £300 on a gpu and only having a 2 year warranty? I have indeed had 2 gpu's die and so far they have been the only components I have ever had die. Actually, I had a maxtor hard drive die too but that isn't much of a surprise as maxtor were terrible.
Odly enough with all the people in the world using pc's you'd expect a fair few of them to have had multple gpu's fail. I happen to be one of them and it's cost me a lot as a result. I had an ocuk 8800GTX die shortly after its 1 year warranty with ocuk annoyingly.
probably a bad PSU, I would look into that if i was you:D
Seasonic m12 600w. I did indeed think it was the psu causing them and I am still unsure as my pc went through a real bad stage and then fixed its self magicaly some how, but i've only had 1 gpu die on this psu. It is also one of the best 600w, if not the best, psu you can buy. The other one was in an older pc. Also my best friends pc had an ocuk 8800GTX die, though his lasted 4 years compared to my 1.5 years.
