Adobe CS4 compatibility.
28 Jan 2011
Hello guys, im new to the forum, had spent a lot of time with Macs and now back to PCs.
Im going to be ordering a system next week but have a few issues.
1. Will adobe CS4 Master Suite run (as im planning on 3 22" or 24" monitors) through the Asus GTX 460's in a Sli configuration?
2. Also was looking at the AMD Phemon II or would I be better off with the Sandy Bridge 2500K?
Thanks guys!
RIJ
I don't see why the 460's in sli would be an issue. Cs4 does use the gpu but I'm sure it will be fine. I'd go sandybridge with plenty of RAM if it were me.
Yeah for a setup that size I'd probably go Sandy Bridge 2500k (maybe even a 2600k if you can stretch to it) and a reasonable chunk of RAM...
Shouldn't see why it would be an issue. I'm currently using Ultramon for managing my windows, and that's got a lovely instant stretch for Photoshop(or any program actually) across my two monitors :)
kd
Always thought CS4 acceleration was on a single GPU.
I have heard a lot that it is. But if needs the Multiple cards to Drive the monitors it will work, but any GPU features/Accelartions within CS4 will only use the Primary Graphics Card.
