Last minute spec check
15 Jan 2009
After selling my iMac I'm treating myself to a nice new PC :)
Any glaring mistakes or omissions from my build? How about the components, anything better for the money?
Well, the motherboard in that bundle will not allow for proper crossfire - which would give you a performance boost for relatively low cost, when you feel performance begin to drop.
This Foxconn P67A-S motherboard will let you do that, and push your overclock as high as the ASUS, if not higher for a low price.
Sorted for the optical and hard drive already.
Swapped the GFX, RAM, and Motherboard over.
Changed the monitor for the non-led version after deciding I'll probably use the HDMI quite a bit to be honest.
All good?
Yup!
Well no, that PSU won't handle CF unfortunately.
I believe this would do the job (but stulid knows better than I about PSUs for CF, might be worth waiting for his go-ahead!)
then keep that psu, and the bundle if you want.
The GPU and RAM were the two important changes to save some ££
