i7 2600 "K"
Possibly the only one on these forums, but I'm guessing a small % of the people who bought the K chips will run them at stock speeds.
How does the Warranty work though?
Because i got the Full Retail one with 3 Years Warranty, If i overclocked to say 4Ghz? Would that void the Warranty? (Like it has done on all other CPUs known to man :( )
Overclockers and Intel will still honour any warranties (providing people haven't done something like lapping the CPU).
Dont Know why someone would do that :| I Certainly wouldnt do that, im happy with it at stock :D
EDIT: Googled what it was my self.
lapping is basically sanding it to make it as flat as possible. Theoretically it will give you slightly better contact between the cpu and heatsink; so you can sometimes knock a few degrees off the temps.
:| Im scared to touch anything inside my case without a Anti-Static lead. So to me that just pure Stupidity :O
I'm keeping my 2500k at stock right now, it runs everything i need it to at a blistering pace and also want to wait till the asus mobo problems are ironed out before i change too much.
If in a year or so I need the extra oomph an oc would give me then I'll do it then and be glad I got the K version :)
+1
if you have no intentions of overclocking your 2500k or 2600k is the stock Intel cooler sufficient for the job or 'should' you really consider replacing it as part of a new build?
