- 1 Mar 2004
- Cardiff, UK
Well, I'm still awaiting the delivery man at the moment! I'll let you know when I get a chance to try them both out. (Hopefully take some pictures too if I have time)
Alternatively, I'd recommend the Audio-Technica ADH-AD700's and the Speedlink Mic:
http://eu.audio-technica.com/en/products/product.asp?catID=5&subID=37&prodID=156
His budget is only £60 though. Those headphones you mentioned are almost double that.
Phoenix, i've just re-read this thread and you don't have a dedicated sound card. To stay within your £60 budget, i would go with some USB headsets. Problem with these is that you can't use them anywhere else and the quality of the drivers won't be anywhere near as good as those from other reputable manufacturers drivers.
Is the Creative Labs SB X-Fi Xtreme Audio PCI Sound Card better than the Asus Xonar DG 5.1 ? i see it has 1 x SPDIF-In and 1 x SPDIF-Out does this mean i could run the optical from my ps3 to my pc and output it through the pc speakers ? im currently using a splitter and a 3.5mm connector between headphone port on tv and the green input on my logitech 540.
all responses are welcome and i have forbidden myself from following globals blog any more![]()
please have mercy , im currently happy with getting the Xonar Dg's amp XD
from what ive read the pc 350 is basically a hd 555 with a good mic with the pc 360 being around the 595 quality. I was put off the goldrings due to needing batteries and the noise canceling hiss.
