- 26 Aug 2003
I think that might be my problem as well
Cheers!
Cheers!
idiot. all you need to shave is a good razor. you dont need a brush or any of that rubbish.
edit: and gillettte is crap btw.
edit: were you being sarcastic???![]()
Not really, there are obviously going to be some over-sensetive faces out there that will react badly to this type of razor, which makes them "A very good razor" by opinion.they are the best razors ever. simple.
Everyone needs to try a T-1000 then...The best razor ever, will be the one that suits the individual.![]()
listen...mate... i use this razor, with a shaving cream, which you use like a shaving foam, with my hands, which costs a quid. bargain. give it a go. the stuff is called ingram green.
the brush and soap bull**** is rubbish. trust me.
You really have to use the soap and badger brush.
Otherwise you wouldn't look like enough of a pompous ****
