seen a few threads suggesting if various contraptions can "make free" energy.
now, I'm not going to insult you by suggesting that the laws of thermodynamics can be violated
however, most of the energy around us goes unused, so take a look below and tell me if you think this machine is possible:
This is a microscopic machine, say about 100 microns in size.
It is built from two basic components: one is a pipe-like structure (something like a microtubule http://en.wikipedia.org/wiki/Microtubule)
The other part is an axle inside the microtubule.
See a picture of this structure:
The red part has a lumen that is not exactly cylindrical, but rather notched.
This makes rotation of the blue part impossible in a clockwise direction, and only possible anticlockwise by a gentle compression of the red notched area.
Ok that's enough microanatomy!
Anticlockwise rotation of the blue part will generate energy, eg. by generating ATP molecules http://en.wikipedia.org/wiki/Adenosine_triphosphate
Exact details about how ATP is generated is not needed, but similar chemical reactions are know to exist in nature. The point is we are utilising energy from the compression of the red notched bit to make covalent bonds.
The blue bit is prevented from rotating clockwise to prevent the reverse chemical reaction.
Soooo - what force are we using to rotate the blue bit?
Well, it's a free and abundant force: brownian motion. See the image below:
Basically the blue and red bits are attached to larger structures which constantly jiggle about but due to the molecular ratchet mechanism the blue bit only moves in one direction, generating high energy bonds, for us to use later...
So, is this possible? What do you think?
