Just under 18k ppd for GTX 570.
27 Mar 2010
Got my 570 to 913Mhz from 732Mhz stock and have been folding on it for 2 hours with no troubles yet.
Check out the PPD,
I thought that was just a lucky WU...
But that must be at stock, as you can see in my posts the 570 OC'd gets 19k ppd, whereas the 560 OC'd might get close to 17k.
That'd be my guess anyway.
If thats @ stock, I wonder what the Gigabyte GTX560 SOC can achieve with it's 1000MHz Core Clock (2000MHz Shader).
I think it should be somewhere close to the 570's (even oc'd).
Stock currently overdue @ OcUK, but it might be worth considering @ approx £50 cheaper than the stock 570's.
t'is just a thought :D
