- 2 Jul 2005
You must be worried about something but I won't insult you and ask if you can use a screwdriver!
Truth is, computer hardware is far more robust these days - with special coating over solder joints etc... only time I use an anti-static wrist band is when working on other peoples equipment, simply for good measure.
I second the above posts. Try it and just post back on this thread if you get stuck. Like one thing you might wonder is what happens if you don't use the rubber washers ? well those silver dots around the screw placeholders are there to ground the screws so that you don't need the washers!
