Hi there
First of all here is the product:-
BenQ C1230 12MP Compact Digital Camera - Silver/Pink @ £44.99 inc VAT
The BenQ C1230 is ideal for anyone who just wants a simple point and click compact digital camera that is easy to use and takes good quality photos. Its ideal for children, students and even those looking to get into photography. Robust and small enough to take everywhere with you, so you never miss the opportunity to take a photo and at a cost where if the kids do break it or drop it then its not cost the earth, making this camera an ideal gift for Birthdays, Christmas, Valentines Day etc.
With smart scene mode automatically detects 8 different types of scenes and chooses an appropriate one out of the following 8 scene modes: Landscape, Portrait, Backlight, Backlight Portrait, Night Scene, Night Portrait, Macro, and Sunset. All you have to do is press the shutter and the Auto Scene Mode will do the rest for you.
With 5cm Macro, it will automatically scan and switch to the Macro mode when you are taking close-up photos of flowers or small objects. So every photo is in focus.
Want to take a good photo when there are just two of you? Love Portrait mode will take a shot when detecting at least two faces.
Blink Detector alerts you when a subject has blinked, allowing the shot to be retaken immediately or saved according to your preference.
Specification:-
- Sensor SONY 12 Mega Pixels, 1 / 2.3 inch CCD
- Picture Resolution 12M / 3:2 / 8M / 5M/ 3M / HD 16:9 / VGA
- Lens f = 6.2 ( W ) ~ 18.6 ( T ) mm
- F= 3.0 (W) ~ 5.6 (T) (f = 34.6~103.8mm, 35mm equivalent)
- Zoom Optical: 3X
- Digital: Up to 5X (Preview) / Up to 12X (Playback)
- Focus Range Normal: W=80cm ~ Infinity
- Macro: W=5cm ~ 100cm
- Shutter Speed 1/2000 ~ 1 sec. (Fireworks 2 sec.; Manual 15 sec.; Night Scene 8 sec.)
- Display Size 2.7" LCD
- Display Resolution 230,000 pixels
- ISO Equivalent Auto / 50 / 100 / 200 / 400 / 800 / 1600 / 3200 (3M or lower) / 6400 (VGA and HD 16:9 only)
- White Balance Manual (6 modes in manual selection : Daylight / Cloudy / Tungsten / Fluorescent H / Fluorescent L / Manual)
- Flash Auto Flash, Auto Anti Red-eye, Force On, Slow Sync, Forced Off
- Self-Timer 2 sec. / 10 sec. / Double / Burst
- Movie Mode 720 x 400 (16:9) / 640 x 480 / 320 x 240 / Web sharing
- 30 fps, Continuous recording with sound
- Storage Built-in Approx. 21.1MB
- 4GB SD compatible / 32GB SDHC card compatible
- Interface Digital output: USB 2.0 compatible
- Audio / Video output (NTSC/PAL)
- PictBridge compatible
- Battery AA Battery x 2
- CIPA Approx 200 base on bundled batteries
- Dimensions (W x H x D) 92.0 x 60.5 x 23.8 mm
- Weight 120 g (without battery & SD card)
- Accessories (Standard) USB Cable / Software & UM CD / Quick Guide / Hand Strap / Pouch /AA Battery x 2
- Product Color: Silver / Pink
- 2yr Warranty
Was [£59.99] Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Now this camera is ideal for anyone who wants to buy a camera for their children as its easy to use and for the money gives great quality photos, also as the casing is a soft silver/purple colour it could also be ideal for girls and valentine gifts. Or you just might want a cheap compact camera to carry around in case you ever need one.
Here are some photos I've taken this morning:-
The camera is very easy to use, simply point, hold the focus button miday and once focused push all the way, picture is taken. Outdoor photos in natural light come out rather well, indoor photos do have some noise to them, but all photos were taken without the flash and in automatic mode.
For the money this is a very good camera that takes more than acceptable photos, especially outdoors and is ideal for kids or as a gift who wants something easy to use.
Don't buy this camera expecting pixel sharp quality and truly stunning photos, for that you need something far more high-end costing well over £100, most likely £200-£300, so considering this camera is sub £50 its an absolute bargain and OcUK's price is the lowest in the UK.
Specification:-
- Zoom Optical: 3X
- 2yr Warranty
ORDER NOW
