Permabanned
- 9 Aug 2008
Then "**** off" normally does the job![]()
Correct, this.
I find the most annoying thing is that when you get known as the IT person where you live, everyone else instantly becomes infinitely stupider, and problems they would have done themselves before are now your job permanently...
For me it's usually because they have installed 5 antivirus versions on the one PC and each version insists on scanning everything they do....
When asked why they have so many versions the answer is
"computer told me to install it so I clicked install"![]()
get them to drop it off, keep it for a few days, tell them you cannot work out whats wrong and send the off to the local computer shop.
when someone wants something configuting, go there fiddle for half an hour say you dont know how to fix it and send the off to the local computer shop.
NEVER build PC's for friends, get them to buy one from PC world, its not any cheaper if you try and cobble one together and its loads more hastle..
Even if you send someone to the purple shirt people, you are going to end up sorting their PC out after PC world fill it with all the crap when they sell pre-built systems. And oh when their Anti-virus expires, you are going to be stuck with a heavily infected PC because people have been running without an AV for x months.
Or you get people who install several AV packages at once thinking its (triple protection)
Fail
even if you build them a PC their AV will expire and need sorting.... it only takes 30mins to remove all the preinstalled crap... and you are not responsble for the hardware if they brought it from another company so thats less for you to have to fix if there is an issue
Why oh why.
I have custom built my own PC about 4 times (3 different rigs).
Originally Posted by Jaffa_Far View Post
Why oh why.
Why oh why.
