Today Only we have 12 units of Logitech G27 Racing Wheel for just £214.99 inc. VAT. A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3.
We also have 20 units of OcUK ATI Radeon 6950 2048MB Graphics Card for just £204.98 inc. VAT. The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. Perfect for running all the latest games at the highest resolution.
Logitech G27 Racing Wheel - PC / PS2 / PS3 (941-000047) ** IN STOCK NOW ** @ £214.99 inc VAT
A simulator-grade racing wheel, the Logitech G27 Racing Wheel is designed to deliver the definitive sim racing experience for the PC and Playstation 3. Its powerful, dual-motor force feedback mechanism with helical gearing smoothly and accurately simulates traction loss, weight shift and road feel, with exceptionally quiet steering action. The six-speed shifter with push-down reverse gear allows you to quickly choose exactly the right gear. New RPM/shift indicator LEDs let you know when you should shift gears; the 28-cm leather-wrapped rim provides hours of comfortable, true-to-life racing; and steel accelerator, brake and clutch pedals deliver precise control for heightened realism.
- Dual-motor force feedback mechanism with helical gearing
- RPM/shift indicator
- Sixteen programmable buttons plus D-Pad
- 900 degree wheel rotation
- Ultra-precise optical encoding
- Carpet Grip System
- 6 Speed Gear Shifter
- Steel gas, brake and clutch pedal
- Steel ball bearings
- Works with PC, PS2, PS3
Only £214.99 inc VAT.
ORDER NOW
OcUK ATI Radeon 6950 2048MB GDDR5 PCI-Express Graphics Card @ £204.98 inc VAT
The ATI Radeon HD 6900 series features the latest graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU’s are built in AMD’s 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, new AA and image filtering options, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
Features:-
- Core Clock: 800MHz
- Memory: 2048MB GDDR5
- Memory Clock: 5000MHz (Effective)
- Memory Bandwidth: ??GB/sec
- Processing Cores: 1408
- Texture Units: 88
- ROPS: 32
- Bus Type: PCI-Express 2.1
- Display Connectors: 2 Dual-Link DVI-I, 1 HDMI & 2x Mini-DisplayPort
- HDCP Capable
- DirectX 11 Support
- Shader Model 5.0 Support
- OpenGL 4.0 Support
- ATI CrossFire Ready
- ATI Eyefinity Technology
- ATI Avivo HD
- ATI Stream Technology
- ATI HD3D Technology
- Maximum Power Consumption: 250W (Typical 190W)
- 2x 6pin PCI-E power connectors required
- 450W minimum PSU recommended
- Warranty: 2 Years
Only £204.98 inc VAT.
ORDER NOW
ORDER NOW
Features:-
- Texture Units: 88
- ROPS: 32
- HDCP Capable
- ATI Avivo HD
- Warranty: 2 Years
ORDER NOW
