Vauxhall Astra - bonnet won't open
If you feel down by the pull handle you should be able to feel the cable pull this rather than the handle you may need to use pliers to give it a good yank. Otherwise you can try applying pressure to the bonnet and doing the same whilst pulling the release tab. Otherwise you will need to remove the Grill and force the release this usually means breaking the grill to get access...
This has worked for me, pull the cord, then go to the bonnet and apply a quick push in a downward direction, this works for my missus 2002 astra.
works a lot better if you have someone pressing on the bonnet, then you pull the lever and hold it up, release bonnet and it should/can open.
Then adjust it up or you'll be swearing next time as it only gets worse over time!
