In all honesty if you're testing the cable you basically need to check the signal going in one end if the same coming out the other end, no need for complicated setups or anything, you simply want to eletrically check the signal going in is the the one that comes out the end.
Again I have been unclear.
I would like to test the difference different cables make to me with my equipment in my home environment. It is for my interest sake and I was suggesting posting the results here.
Taking a photo of the screen proves nothing. I'm pretty sure if you take the same photo 5 seconds later and compare it to the previous one it will show colour differences in the image.
Thanks, that sounds like a good idea. I presume from what you typed that you have not actually tried it and you are guessing.
Instead of becoming obsessed with trying to prove a difference why don't you save the time and watch a film.
Refer to my first reply to your post. Want to test , my home, my equip, happy to post results. No obsession about it. The only obsession I can see is the number of people who have jumped up trying to convince me not to even try. Seriously, what are you guys afraid of if I do this test and post the results. Why are you so dead set on me not doing it.
If someone else posted this then I would be interested, would read the results and add my own research and come to my own conclusions. Are you all worried that others here cannot do the same.
People, you seem to be taking this so seriously. It is unlikely to debunk all your scientific beliefs. Be cool. i believe I say a picture difference with two different cables and just want to see them again to see if I was mistaken or not. As someone suggested, one of the cables may not have supported deep colour and have a lower bandwidth. That may also explain the differences.
[sigh] well it seems most people here are against someone trying something or more likely, about someone publishing the results.
Pug, you are so right. Don't mess with a guys woman, car, shed or hifi. Some people seem to get very touchy (not is a good way).
RB
