- 7 Dec 2008
Simple question really guys, I am using an AX1200, should I put the fan up or down?
Thanks so i will put it upwards. Finnaly with the OC bundles' if i buy the same amount of rame, same amount of sticks and the same model, will i need to re-oc my machine or will it just work? Thanks guys.
