Fantastic deal on theese. Running dual gigabyte 470 oc's here, comfortably run 750 mhz on stock volts, ran them a few times at 800 mhz on 1.075, always been meaning to test how low i can get the voltage to go on them for 800.
Tbh, ive only ran a few benchmarks with them at 800, 3dm 11, heaven 2.1 etc. At a rather modest 750 mhz they breeze their way through anything i play at 1920x1200, as theyre on stock voltage they run fairly cool, and i can use auto fan which keeps them very quiet.the problem is if your slightly undervolting these cards the performance would be less, the smart thing would probably be to overclock with high volts get a 3dmark score and clock it down till you get to the point where the marks start to drop off
Gibbo - how many are you getting?
MSI seems to give you guys some exclusive deals. =)
1000 units, but 560 have been sold already, as we sold 300 in one go, expected to have sold out very quickly and the price is going up Friday. So you want one at this price you gotta pre-order.
750watt + GTX470 SLI with i5/7+ probably isn't a good idea. Definitely gonna have to stay away from intensive benchmarks/overclocking. Running heaven benchmark with 800MHz clocks on mine pushed the PSU right to the edge and I'm running ~100watt less than a typical equivalent i7 setup.
As do Asus and many other vendors.![]()
all reviews i've seen show stock clocked 470 sli with the older much more power hungry 1st gen i7@4ghz ish using like 550w on furmark, i have no interest in stupid benchmarks or stress testing only real game loads, should be fine
[TW]Fox;18363307 said:Will stick with the 480. Faster out of the box by quite some margin and hardly expensive at 195 quid.
Uh-oh....feel another wobble coming along
480 = 25% on average better performance across the board, but reference cooler and 35% more expensive. Power-hungry, as loud as a 280, but in that price bracket cannot be matched for performance.
470 = cheaper, cooler, 25% less of a card. Unmatched for price-performance in its bracket.
Myself = indecisive, confused, frustrated![]()
